跳转到主内容
LG Optimus T Camera and Camera Mount Replacement
你所需要的
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: 步骤 1 中的图像 1,2 LG Optimus T Camera and Camera Mount Replacement, Camera: 步骤 1 中的图像 2,2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: 步骤 3 中的图像 1,1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: 步骤 4 中的图像 1,2 LG Optimus T Camera and Camera Mount Replacement: 步骤 4 中的图像 2,2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: 步骤 5 中的图像 1,1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: 步骤 6 中的图像 1,1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: 步骤 7 中的图像 1,2 LG Optimus T Camera and Camera Mount Replacement: 步骤 7 中的图像 2,2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
结论
stacey
于02/07/17注册
219 声望
创作了2篇指南
团队
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017 的会员
OSU-WILDER-S17S1G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 108
