跳转到主内容
LG Optimus L9 P769 Micro-USB Port Replacement
你所需要的
  1. LG Optimus L9 P769 Micro-USB Port Replacement, Micro-USB Port: 步骤 1 中的图像 1,1
    • Power off the device and gently lift the battery cover off to access the battery
  2. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery from the notch in the edge of the battery compartment
  3. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 3 中的图像 1,2 LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 3 中的图像 2,2
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using a PH000 screwdriver.
  4. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 4 中的图像 1,2 LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 4 中的图像 2,2
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  5. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 5 中的图像 1,3 LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 5 中的图像 2,3 LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 5 中的图像 3,3
    • Remove both connections of the antenna by pulling up with tweezers
  6. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 6 中的图像 1,3 LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 6 中的图像 2,3 LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 6 中的图像 3,3
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  7. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 7 中的图像 1,1
    • Detach module from motherboard using a prying tool
  8. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 8 中的图像 1,2 LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 8 中的图像 2,2
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  9. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 9 中的图像 1,2 LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 9 中的图像 2,2
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  10. LG Optimus L9 P769 Micro-USB Port Replacement: 步骤 10 中的图像 1,1
    • Comparison showing the Micro-USB module against the empty phone casing
结论
Kayden G
于03/01/17注册
272 声望
创作了2篇指南
团队
IUPUI, Team S2-G1, Harley Spring 2017 IUPUI, Team S2-G1, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S2G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 323
