跳转到主内容
LG Optimus L7 P705 Home Button Replacement
你所需要的
  1. LG Optimus L7 P705 Home Button Replacement, Home Button: 步骤 1 中的图像 1,2 LG Optimus L7 P705 Home Button Replacement, Home Button: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. LG Optimus L7 P705 Home Button Replacement: 步骤 2 中的图像 1,1
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. LG Optimus L7 P705 Home Button Replacement: 步骤 3 中的图像 1,1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Home Button Replacement: 步骤 4 中的图像 1,2 LG Optimus L7 P705 Home Button Replacement: 步骤 4 中的图像 2,2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 Home Button Replacement: 步骤 5 中的图像 1,1
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  6. LG Optimus L7 P705 Home Button Replacement: 步骤 6 中的图像 1,1
    • Remove the home screen button. Replace as needed.
结论
另外一个人完成了本指南。
Bruna
于10/08/14注册
525 声望
创作了4篇指南
团队
USF Tampa, Team 9-1, Leahy Fall 2014 USF Tampa, Team 9-1, Leahy Fall 2014 的会员
USFT-LEAHY-F14S9G1
3 名成员
创作了5篇指南
一条评论
in the step 2, one red ring is in the wrong position.
The ring in the midle at the left side is in the center of the telephone
Tiago - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,801
