跳转到主内容
LG Optimus L7 P705 Headphone Jack Replacement
你所需要的
  1. LG Optimus L7 P705 Headphone Jack Replacement, Display: 步骤 1 中的图像 1,2 LG Optimus L7 P705 Headphone Jack Replacement, Display: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and simcard.
  2. LG Optimus L7 P705 Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
  3. LG Optimus L7 P705 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Headphone Jack Replacement: 步骤 4 中的图像 1,2 LG Optimus L7 P705 Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 Headphone Jack Replacement: 步骤 5 中的图像 1,2 LG Optimus L7 P705 Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Flip over to the face of the device.
    • Lift off glass screen (display).
  6. LG Optimus L7 P705 Headphone Jack Replacement, SIM Card Slot: 步骤 6 中的图像 1,2 LG Optimus L7 P705 Headphone Jack Replacement, SIM Card Slot: 步骤 6 中的图像 2,2
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  7. LG Optimus L7 P705 Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  8. LG Optimus L7 P705 Headphone Jack Replacement: 步骤 8 中的图像 1,2 LG Optimus L7 P705 Headphone Jack Replacement: 步骤 8 中的图像 2,2
    • Detach the mount including both the SIM card and the motherboard from the device.
  9. LG Optimus L7 P705 Headphone Jack Replacement, Headphone Jack: 步骤 9 中的图像 1,1
    • Lift off the connector using the plastic spudger.
  10. LG Optimus L7 P705 Headphone Jack Replacement: 步骤 10 中的图像 1,1
    • Lift the speaker connector using the plastic spudger.
  11. LG Optimus L7 P705 Headphone Jack Replacement: 步骤 11 中的图像 1,3 LG Optimus L7 P705 Headphone Jack Replacement: 步骤 11 中的图像 2,3 LG Optimus L7 P705 Headphone Jack Replacement: 步骤 11 中的图像 3,3
    • Flip over to the back of the device. Lift off the connector on the left using the plastic spudger.
    • Lift off the headphone jack connector on the top right using the plastic spudger.
    • Replace the board containing the headphone jack.
结论
Tianyu Song
于01/24/17注册
107 声望
撰写一个指南
团队
IUPUI, Team 2-2, Baechle Spring 2017 IUPUI, Team 2-2, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S2G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 397
