跳转到主内容
LG Optimus L7 P705 Display Replacement
你所需要的
  1. LG Optimus L7 P705 Display Replacement, Display: 步骤 1 中的图像 1,2 LG Optimus L7 P705 Display Replacement, Display: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and simcard.
  2. LG Optimus L7 P705 Display Replacement: 步骤 2 中的图像 1,1
    • Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
  3. LG Optimus L7 P705 Display Replacement: 步骤 3 中的图像 1,1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Display Replacement: 步骤 4 中的图像 1,2 LG Optimus L7 P705 Display Replacement: 步骤 4 中的图像 2,2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 Display Replacement: 步骤 5 中的图像 1,2 LG Optimus L7 P705 Display Replacement: 步骤 5 中的图像 2,2
    • Flip over to the face of the device.
    • Lift off glass screen (display).
结论
8等其他人完成本指南。
Craig Lashley
于10/08/14注册
307 声望
撰写一个指南
团队
USF Tampa, Team 9-1, Leahy Fall 2014 USF Tampa, Team 9-1, Leahy Fall 2014 的会员
USFT-LEAHY-F14S9G1
3 名成员
创作了5篇指南
2条评论
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Sooty - 回复
Im miles i great this ifixit i'm beginner
Omair Sarip -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 5,393
