当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Once you have properly removed the outer casing, the back should look as so.
To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
Once the battery is removed you may safely proceed to the next step.
即将完成!
终点
10等其他人完成本指南。
