跳转到主内容
LG Optimus G Battery Replacement
你所需要的
  1. LG Optimus G Battery Replacement, Remove the simcard: 步骤 1 中的图像 1,2 LG Optimus G Battery Replacement, Remove the simcard: 步骤 1 中的图像 2,2
    • SIM eject tool
  2. LG Optimus G Battery Replacement, Remove the back cover: 步骤 2 中的图像 1,2 LG Optimus G Battery Replacement, Remove the back cover: 步骤 2 中的图像 2,2
    • Remove the 2 screws holding the back cover using a T5 screwdriver.
    • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Use an opening pick to pry off the rear case.
  3. LG Optimus G Battery Replacement, Removing the battery: 步骤 4 中的图像 1,2 LG Optimus G Battery Replacement, Removing the battery: 步骤 4 中的图像 2,2
    • Remove the tape over the battery, the screws and the antenna connector cord.
    • Be careful removing the golden tape because it is below the antenna connector cord.
  4. LG Optimus G Battery Replacement: 步骤 5 中的图像 1,2 LG Optimus G Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the the screws securing the battery cable connector.
    • Disconnect the battery cable.
  5. LG Optimus G Battery Replacement: 步骤 6 中的图像 1,1
    • The battery is held down by some adhesive.
    • Carefully heat the battery to loosen the adhesive holding it to the case.
  6. LG Optimus G Battery Replacement: 步骤 7 中的图像 1,2 LG Optimus G Battery Replacement: 步骤 7 中的图像 2,2
    • Pry the battery up from the case.
    • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  7. LG Optimus G Battery Replacement: 步骤 8 中的图像 1,3 LG Optimus G Battery Replacement: 步骤 8 中的图像 2,3 LG Optimus G Battery Replacement: 步骤 8 中的图像 3,3
    • The battery is removed.
    • Replace the battery with a new one.
结论
7等其他人完成本指南。
Eneider Colina
于09/20/13注册
2,362 声望
创作了9篇指南
团队
Comunidad para traductores de español Comunidad para traductores de español 的会员
Community
23 名成员
创作了193篇指南
5条评论
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - 回复
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - 回复
Where do you suggest ordering a replacement battery from?
snack le - 回复
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
https://www.phonepartworld.com/LG/LG-Opt...
ricksanchez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 5,093
