跳转到主内容
LG Optimus G Battery Replacement
你所需要的
  1. LG Optimus G Battery Replacement, Remove the simcard: 步骤 1 中的图像 1,2 LG Optimus G Battery Replacement, Remove the simcard: 步骤 1 中的图像 2,2
    • SIM eject tool
  2. LG Optimus G Battery Replacement, Remove the back cover: 步骤 2 中的图像 1,2 LG Optimus G Battery Replacement, Remove the back cover: 步骤 2 中的图像 2,2
    • Remove the 2 screws holding the back cover using a T5 screwdriver.
    • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Use an opening pick to pry off the rear case.
  3. LG Optimus G Battery Replacement, Removing the battery: 步骤 4 中的图像 1,2 LG Optimus G Battery Replacement, Removing the battery: 步骤 4 中的图像 2,2
    • Remove the tape over the battery, the screws and the antenna connector cord.
    • Be careful removing the golden tape because it is below the antenna connector cord.
  4. LG Optimus G Battery Replacement: 步骤 5 中的图像 1,2 LG Optimus G Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the the screws securing the battery cable connector.
    • Disconnect the battery cable.
  5. LG Optimus G Battery Replacement: 步骤 6 中的图像 1,1
    • The battery is held down by some adhesive.
    • Carefully heat the battery to loosen the adhesive holding it to the case.
  6. LG Optimus G Battery Replacement: 步骤 7 中的图像 1,2 LG Optimus G Battery Replacement: 步骤 7 中的图像 2,2
    • Pry the battery up from the case.
    • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  7. LG Optimus G Battery Replacement: 步骤 8 中的图像 1,3 LG Optimus G Battery Replacement: 步骤 8 中的图像 2,3 LG Optimus G Battery Replacement: 步骤 8 中的图像 3,3
    • The battery is removed.
    • Replace the battery with a new one.
结论
7等其他人完成本指南。
Eneider Colina
于09/20/13注册
2,370 声望
创作了9篇指南
5指南评论
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - 回复
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - 回复
Where do you suggest ordering a replacement battery from?
snack le - 回复
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
https://www.phonepartworld.com/LG/LG-Opt...
ricksanchez - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 5,390
