跳转到主内容
LG Optimus Fuel Speaker Replacement
你所需要的
  1. LG Optimus Fuel Speaker Replacement, Battery: 步骤 1 中的图像 1,2 LG Optimus Fuel Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the opening on the right side of the phone to pull off the plastic back cover.
  2. LG Optimus Fuel Speaker Replacement: 步骤 2 中的图像 1,3 LG Optimus Fuel Speaker Replacement: 步骤 2 中的图像 2,3 LG Optimus Fuel Speaker Replacement: 步骤 2 中的图像 3,3
    • Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
  3. LG Optimus Fuel Speaker Replacement, Speaker: 步骤 3 中的图像 1,3 LG Optimus Fuel Speaker Replacement, Speaker: 步骤 3 中的图像 2,3 LG Optimus Fuel Speaker Replacement, Speaker: 步骤 3 中的图像 3,3
    • Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 bit. Then fully remove the back panel with a plastic opening tool.
  4. LG Optimus Fuel Speaker Replacement: 步骤 4 中的图像 1,3 LG Optimus Fuel Speaker Replacement: 步骤 4 中的图像 2,3 LG Optimus Fuel Speaker Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the speaker from the back panel. You may have to use some tweezers if you are having a hard time grabbing the speaker with your fingers.
    • Remember to take note of where the two springs on the speaker are positioned before removing it. Install the new speaker with the springs in this same position.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 265
