跳转到主内容
LG Optimus F3 Motherboard Replacement
你所需要的
  1. LG Optimus F3 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
  2. LG Optimus F3 Motherboard Replacement: 步骤 2 中的图像 1,1
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
  3. LG Optimus F3 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
  4. LG Optimus F3 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
  5. LG Optimus F3 Motherboard Replacement: 步骤 5 中的图像 1,1
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
  6. LG Optimus F3 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
  7. LG Optimus F3 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
  8. LG Optimus F3 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
  9. LG Optimus F3 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
结论
3等其他人完成本指南。
团队
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 588
