跳转到主内容
LG Optimus F3 Headphone Jack Replacement
你所需要的
  1. LG Optimus F3 Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • Place your thumb at the bottom of the phone's back where the charging port is located.
    • Gently pull the cover off.
  2. LG Optimus F3 Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Using the indent at the bottom of the battery, lift and remove the battery from the phone.
    • Place the battery in a safe location as you will need it for reassembly.
  3. LG Optimus F3 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Remove the ten 1.0 mm screws on the rear case.
    • Place the screws in a safe location as you will need them for reassembly.
  4. LG Optimus F3 Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Pry apart the joints to separate the inner case.
    • Insert the opening tool on different locations until the case comes off easily.
    • To avoid damaging the joints of the case do not pry if there is resistance.
  5. LG Optimus F3 Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • With the inner cover removed, locate your headphone jack.
    • It will be in the upper right corner on the back of the phone.
  6. LG Optimus F3 Headphone Jack Replacement: 步骤 6 中的图像 1,1
    • Gently grab the headphone jack along the sides with tweezers.
    • Lift the headphone jack out of its socket.
  7. LG Optimus F3 Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Insert the new headphone jack into the headphone socket by lining up the connectors and gently pressing down.
    • Make sure the dark side without the connectors is face up.
结论
To reassemble your device follow these steps in reverse order.
4等其他人完成本指南。
Ryan McDermott
于10/28/15注册
324 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 523
