跳转到主内容
LG Optimus Exceed 2 Screen Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. LG Optimus Exceed 2 Screen Replacement, Battery: 步骤 1 中的图像 1,2 LG Optimus Exceed 2 Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the device over and remove the back covering.
  2. LG Optimus Exceed 2 Screen Replacement: 步骤 2 中的图像 1,1
    • Push on the top of the battery downward and pull the battery off of the device.
  3. LG Optimus Exceed 2 Screen Replacement, Rear Camera: 步骤 3 中的图像 1,3 LG Optimus Exceed 2 Screen Replacement, Rear Camera: 步骤 3 中的图像 2,3 LG Optimus Exceed 2 Screen Replacement, Rear Camera: 步骤 3 中的图像 3,3
    • Remove the eleven 4mm screws using a Philips head screw driver.
  4. LG Optimus Exceed 2 Screen Replacement: 步骤 4 中的图像 1,3 LG Optimus Exceed 2 Screen Replacement: 步骤 4 中的图像 2,3 LG Optimus Exceed 2 Screen Replacement: 步骤 4 中的图像 3,3
    • Insert the plastic opening tool into the side of the device and pry off silver covering. Push up against the back covering when the tool is inserted to detach from the phone.
    • Make sure to detach all sides of silver covering before lifting it off the phone.
  5. LG Optimus Exceed 2 Screen Replacement: 步骤 5 中的图像 1,2 LG Optimus Exceed 2 Screen Replacement: 步骤 5 中的图像 2,2
    • Using the prying tool detach the connector on the device.
    • Insert the plastic opening tool underneath the connector and push tool down to lift the connector from the device.
  6. LG Optimus Exceed 2 Screen Replacement: 步骤 6 中的图像 1,2 LG Optimus Exceed 2 Screen Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers lift the camera off of the device.
    • To do so grasp the camera gently with the tweezers and pull the camera up out of the device.
  7. LG Optimus Exceed 2 Screen Replacement, Motherboard: 步骤 7 中的图像 1,2 LG Optimus Exceed 2 Screen Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Disconnect the remaining ribbon plugs and connectors. (Only remove the highlighted cables for the removal of the logic board.)
  8. LG Optimus Exceed 2 Screen Replacement: 步骤 8 中的图像 1,2 LG Optimus Exceed 2 Screen Replacement: 步骤 8 中的图像 2,2
    • Push the blue lifting tool up underneath the logic board and pull it upwards removing it from the device.
  9. LG Optimus Exceed 2 Screen Replacement, Screen: 步骤 9 中的图像 1,3 LG Optimus Exceed 2 Screen Replacement, Screen: 步骤 9 中的图像 2,3 LG Optimus Exceed 2 Screen Replacement, Screen: 步骤 9 中的图像 3,3
    • Using a prying tool, carefully remove the silver/ black tape used to hide the screens connectors.
  10. LG Optimus Exceed 2 Screen Replacement: 步骤 10 中的图像 1,3 LG Optimus Exceed 2 Screen Replacement: 步骤 10 中的图像 2,3 LG Optimus Exceed 2 Screen Replacement: 步骤 10 中的图像 3,3
    • Using the blue lifting tool carefully remove the screens connectors.
  11. LG Optimus Exceed 2 Screen Replacement: 步骤 11 中的图像 1,3 LG Optimus Exceed 2 Screen Replacement: 步骤 11 中的图像 2,3 LG Optimus Exceed 2 Screen Replacement: 步骤 11 中的图像 3,3
    • Flip the device so the screen faces you. Using a prying tool, at the corners on the screen begin to pry off the screen. (It will sound like tape being removed.) Avoid scratching the device with the prying tool.
  12. LG Optimus Exceed 2 Screen Replacement: 步骤 12 中的图像 1,1
    • Pull the screen off of the body of the device. (Mind the circuits when removing the screen. The home button is likely to fall off. )
结论
Carl Dorvilus
于03/10/16注册
708 声望
创作了6篇指南
团队
UMass Dartmouth, Team 4-4, Catania Spring 2016 UMass Dartmouth, Team 4-4, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 124
