简介
If your home button is not working or you have to press it several times in order to get it to work, then you might want to replace that part of your device. In order to replace the home button of your LG Optimus Exceed 2 phone please follow these steps below.
你所需要的
Disconnect the remaining ribbon plugs and connectors. (Only remove the highlighted cables for the removal of the logic board.)
Using a prying tool, carefully remove the silver/ black tape used to hide the screens connectors.
即将完成!
结论
