跳转到主内容
LG Optimus Dynamic II L39C Screen Replacement
你所需要的
  1. LG Optimus Dynamic II L39C Screen Replacement, Remove the back case: 步骤 1 中的图像 1,2 LG Optimus Dynamic II L39C Screen Replacement, Remove the back case: 步骤 1 中的图像 2,2
    • Make sure not to push the tool into the USB port. Doing so may cause damage to your phone.
    • Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
  2. LG Optimus Dynamic II L39C Screen Replacement, Remove the Battery: 步骤 2 中的图像 1,1
    • Lift the battery out of the phone and replace with your new one.
  3. LG Optimus Dynamic II L39C Screen Replacement, Remove the SD Card: 步骤 3 中的图像 1,1
    • Grab the end of the SD Card and pull it out of the phone.
  4. LG Optimus Dynamic II L39C Screen Replacement, Remove the screws from the midframe: 步骤 4 中的图像 1,2 LG Optimus Dynamic II L39C Screen Replacement, Remove the screws from the midframe: 步骤 4 中的图像 2,2
    • Use the PH #000 screwdriver to remove the six screws from the midframe
  5. LG Optimus Dynamic II L39C Screen Replacement, Remove the midframe: 步骤 5 中的图像 1,2 LG Optimus Dynamic II L39C Screen Replacement, Remove the midframe: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
  6. LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: 步骤 6 中的图像 1,3 LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: 步骤 6 中的图像 2,3 LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: 步骤 6 中的图像 3,3
    • Use the plastic opening tool to disconnect the small orange tab from the motherboard.
    • Next disconnect the silver tab slightly above where the orange tab was.
  7. LG Optimus Dynamic II L39C Screen Replacement, Separate the screen and motherboard: 步骤 7 中的图像 1,1
    • Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
结论
6等其他人完成本指南。
Patrick Barron
于10/08/14注册
158 声望
撰写一个指南
团队
USF Tampa, Team 14-3, Leahy Fall 2014 USF Tampa, Team 14-3, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G3
4 名成员
创作了3篇指南
一条评论
My screen is black but everything else works (even the touch screen -- I can use it to answer calls). I used this guide to change the screens from a working phone - but my screen is still black! Anyone have any ideas?
Jack - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,272
