跳转到主内容
LG Optimus 3D Rear Camera Replacement
你所需要的
  1. LG Optimus 3D Rear Camera Replacement, Back Cover Removal: 步骤 1 中的图像 1,2 LG Optimus 3D Rear Camera Replacement, Back Cover Removal: 步骤 1 中的图像 2,2
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  2. LG Optimus 3D Rear Camera Replacement, Battery Removal: 步骤 2 中的图像 1,3 LG Optimus 3D Rear Camera Replacement, Battery Removal: 步骤 2 中的图像 2,3 LG Optimus 3D Rear Camera Replacement, Battery Removal: 步骤 2 中的图像 3,3
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
  3. LG Optimus 3D Rear Camera Replacement, Screw Removal: 步骤 3 中的图像 1,2 LG Optimus 3D Rear Camera Replacement, Screw Removal: 步骤 3 中的图像 2,2
    • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
    • 5.5mm length PH00 screws
    • 4mm length PH00 screws
  4. LG Optimus 3D Rear Camera Replacement, Bottom Cover Removal: 步骤 4 中的图像 1,2 LG Optimus 3D Rear Camera Replacement, Bottom Cover Removal: 步骤 4 中的图像 2,2
    • Gently pull down on the bottom cover to remove it.
  5. LG Optimus 3D Rear Camera Replacement, Mid-Cover Bezel Removal: 步骤 5 中的图像 1,3 LG Optimus 3D Rear Camera Replacement, Mid-Cover Bezel Removal: 步骤 5 中的图像 2,3 LG Optimus 3D Rear Camera Replacement, Mid-Cover Bezel Removal: 步骤 5 中的图像 3,3
    • Using a plastic opening tool, gently pry around the perimeter of the device.
    • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
    • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
  6. LG Optimus 3D Rear Camera Replacement, Ribbon Cable Disconnection: 步骤 6 中的图像 1,2 LG Optimus 3D Rear Camera Replacement, Ribbon Cable Disconnection: 步骤 6 中的图像 2,2
    • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
  7. LG Optimus 3D Rear Camera Replacement, Adhesive Loosening: 步骤 7 中的图像 1,1
    • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
    • Evenly heat the device in short intervals for about one minute.
    • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
  8. LG Optimus 3D Rear Camera Replacement, SD/SIM Card Board Removal: 步骤 8 中的图像 1,3 LG Optimus 3D Rear Camera Replacement, SD/SIM Card Board Removal: 步骤 8 中的图像 2,3 LG Optimus 3D Rear Camera Replacement, SD/SIM Card Board Removal: 步骤 8 中的图像 3,3
    • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
    • If the board is too difficult to separate than more heating may be required.
  9. LG Optimus 3D Rear Camera Replacement, Heat Adhesive: 步骤 9 中的图像 1,1
    • Heat the camera assembly in 20-30 seconds intervals with a heat gun set on low, or a hair drying set on high.
    • Although the motherboard assembly has been removed in the picture, it is not necessary to remove it for camera removal.
  10. LG Optimus 3D Rear Camera Replacement, Remove Camera Assembly: 步骤 10 中的图像 1,2 LG Optimus 3D Rear Camera Replacement, Remove Camera Assembly: 步骤 10 中的图像 2,2
    • Using tweezers or a pry tool, gently wiggle and lift the camera assembly away from the body of the phone.
    • Although the motherboard has been removed in the pictures, it is not necessary to remove it before removing the camera.
结论
Dale Pearson
于09/22/14注册
784 声望
创作了6篇指南
团队
USF Tampa, Team 10-6, Brown Fall 2014 USF Tampa, Team 10-6, Brown Fall 2014 的会员
USFT-BROWN-F14S10G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 301
