跳转到主内容
LG Notebook LGC40 A410 WiFi module Replacement
你所需要的
  1. LG Notebook LGC40 A410 WiFi module Replacement, Locate the keys to unlock and release the battery: 步骤 1 中的图像 1,1
    • Put the notebook upside down, preferably on top of a soft surface so any movement doesn't scratch the top cover.
    • Locate the keys to unlock and release the battery
  2. LG Notebook LGC40 A410 WiFi module Replacement, Unlock the battery: 步骤 2 中的图像 1,1
    • Slide the unlock key in the indicated direction to unlock the battery
  3. LG Notebook LGC40 A410 WiFi module Replacement, Release and remove the battery: 步骤 3 中的图像 1,2 LG Notebook LGC40 A410 WiFi module Replacement, Release and remove the battery: 步骤 3 中的图像 2,2
    • Slide and hold the release key in the indicated direction
    • Pull out the battery
  4. LG Notebook LGC40 A410 WiFi module Replacement, Remove the WiFi module cover: 步骤 4 中的图像 1,1
    • With the notebook upside down, locate the WiFi module cover and unscrew the philips screw.
  5. LG Notebook LGC40 A410 WiFi module Replacement, Remove the antenna connectors: 步骤 5 中的图像 1,2 LG Notebook LGC40 A410 WiFi module Replacement, Remove the antenna connectors: 步骤 5 中的图像 2,2
    • Locate the antenna connectors on the WiFi module
    • Holding the antenna connectors with the tips of your fingers, carefully pull them out of the WiFi module board.
  6. LG Notebook LGC40 A410 WiFi module Replacement, Remove the WiFi module: 步骤 6 中的图像 1,1
    • Remove the philips screw
    • Lift the WiFi module by the edge where the screw is located
    • Pull the WiFi module from the motherboard connector
结论
另外一个人完成了本指南。
Claudio Felix
于01/01/16注册
833 声望
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 1,176
