本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
With one hand, push the rectangular button located on the back top-side of the phone.
With your other hand, remove the rear cover.
Once you have removed the rear casing flip it over to see a small circular metal piece with 2 gold springs sticking out of the bottom. That is the speaker.
Opposite the 2 small gold springs there will be a small black tab attached to the speaker sitting in a groove. Using tweezers or a small tipped screwdriver lift up on the tab to pop the speaker out.
即将完成!
结论
