跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. With one hand, push the rectangular button located on the back top-side of the phone. With your other hand, remove the rear cover.
    • With one hand, push the rectangular button located on the back top-side of the phone.
    • With your other hand, remove the rear cover.
  2. Remove 5 screws, 1 from each corner of the phone and 1 from the center-right of the phone.
    • Remove 5 screws, 1 from each corner of the phone and 1 from the center-right of the phone.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Now pull off the rear casing, using an opening tool. **Buttons for volume and pictures may fall out** Now pull off the rear casing, using an opening tool. **Buttons for volume and pictures may fall out**
    • Now pull off the rear casing, using an opening tool. **Buttons for volume and pictures may fall out**
  5. Once you have removed the rear casing flip it over to see a small circular metal piece with 2 gold springs sticking out of the bottom. That is the speaker.
    • Once you have removed the rear casing flip it over to see a small circular metal piece with 2 gold springs sticking out of the bottom. That is the speaker.
    • Opposite the 2 small gold springs there will be a small black tab attached to the speaker sitting in a groove. Using tweezers or a small tipped screwdriver lift up on the tab to pop the speaker out.
  6. Replace the broken speaker with a new one (make sure to line up the tab with the groove). Push firmly into place. Follow reverse instructions to put the rear casing and back cover on.
    • Replace the broken speaker with a new one (make sure to line up the tab with the groove). Push firmly into place. Follow reverse instructions to put the rear casing and back cover on.
结论
kristie
于2013年10月23日注册
538 信誉积分
创作了5篇指南
团队
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S2G1
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 124
