跳转到主内容
LG Neon GT 365 Keyboard Replacement
你所需要的
  1. LG Neon GT 365 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 LG Neon GT 365 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • With one hand, push the rectangular button located on the back top-side of the phone.
    • With your other hand, remove the rear cover.
  2. LG Neon GT 365 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove 5 screws, 1 from each corner of the phone and 1 from the center-right of the phone.
  3. LG Neon GT 365 Keyboard Replacement: 步骤 3 中的图像 1,2 LG Neon GT 365 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Now pull off the rear casing, using an opening tool. **Buttons for volume and pictures may fall out**
  4. LG Neon GT 365 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Hold the circuit board and turn the phone upside down.
    • Then let the circuit board hang down so you can disconnect the ribbon by getting under an edge and popping it off. **the rubber keyboard may fall out**
  5. LG Neon GT 365 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Once the circuit board has been removed the rubber keypad will be visible. If it has not fallen out on its own it can simply be peeled out. It is lightly attached like a sticker on the top three tabs. The left most table is labeled “B”, the center tab is blank, and the right tab is labeled “N”.
结论
kristie
于10/23/13注册
538 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S2G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 263
