跳转到主内容
LG Neon GT 365 Case Replacement
你所需要的
  1. LG Neon GT 365 Case Replacement, Case: 步骤 1 中的图像 1,1
    • Remove the back cover of the phone by pushing the rectangular button located on the back top-side of the phone.
  2. LG Neon GT 365 Case Replacement: 步骤 2 中的图像 1,1
    • Use the appropriate screw driver head and remove the six black screws as shown in the picture. A screw may be covered by the slide spring. Move the slide spring to the other side to access that screw.
  3. LG Neon GT 365 Case Replacement: 步骤 3 中的图像 1,2 LG Neon GT 365 Case Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to go around the seem and slowly pull off slide spring assembly.
    • Make sure the ribbon connector does not get caught on other parts of the phone.
  4. LG Neon GT 365 Case Replacement: 步骤 4 中的图像 1,1
    • Remove the connector ribbon located near the bottom of the phone by pulling gently on the ribbon.
  5. LG Neon GT 365 Case Replacement: 步骤 5 中的图像 1,2 LG Neon GT 365 Case Replacement: 步骤 5 中的图像 2,2
    • Carefully, peel off the two green pieces of tape then the gold tape.
  6. LG Neon GT 365 Case Replacement: 步骤 6 中的图像 1,1
    • Disconnect the copper colored ribbon. It is fine to leave the copper ribbon ttached to the top of the phone.
  7. LG Neon GT 365 Case Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool and go around the silver screen and begin to lift it up.
    • Once the silver screen has been lifted up slightly, slide the bottom half of the green circuit board located below the screen off of the phone. Then continue popping the screen out.
  8. LG Neon GT 365 Case Replacement: 步骤 8 中的图像 1,1
  9. LG Neon GT 365 Case Replacement: 步骤 9 中的图像 1,2 LG Neon GT 365 Case Replacement: 步骤 9 中的图像 2,2
    • Disconnect left side of this ribbon.
    • By disconnecting the left side of that ribbon, the phone's screen can be removed from the outer shell.
  10. LG Neon GT 365 Case Replacement: 步骤 10 中的图像 1,1
    • Use the plastic opening tool to remove that speaker out of the groove.
    • Use the plastic opening tool to remove the copper colored plate that the speaker and ribbon is attached to out of the phone.
  11. LG Neon GT 365 Case Replacement: 步骤 11 中的图像 1,1
    • Peel the rubber front keypad out of the case.
  12. LG Neon GT 365 Case Replacement: 步骤 12 中的图像 1,1
    • At this point, all of removable phone components has been taken out. With the new case, follow the steps in reverse to reassemble.
结论
kristie
于10/23/13注册
538 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S2G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 12
总计 305
