跳转到主内容
LG Muziq LX570 Rear Case Replacement
你所需要的
  1. LG Muziq LX570 Rear Case Replacement, Battery: 步骤 1 中的图像 1,2 LG Muziq LX570 Rear Case Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Rear Case Replacement: 步骤 2 中的图像 1,2 LG Muziq LX570 Rear Case Replacement: 步骤 2 中的图像 2,2
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Rear Case Replacement, Rear Case: 步骤 3 中的图像 1,2 LG Muziq LX570 Rear Case Replacement, Rear Case: 步骤 3 中的图像 2,2
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Rear Case Replacement: 步骤 4 中的图像 1,3 LG Muziq LX570 Rear Case Replacement: 步骤 4 中的图像 2,3 LG Muziq LX570 Rear Case Replacement: 步骤 4 中的图像 3,3
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
结论
Matthew Cataldo
于01/23/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G29
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 541
