跳转到主内容
LG Muziq LX570 Front Case Replacement
你所需要的
  1. LG Muziq LX570 Front Case Replacement, Front Case: 步骤 1 中的图像 1,2 LG Muziq LX570 Front Case Replacement, Front Case: 步骤 1 中的图像 2,2
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Front Case Replacement: 步骤 2 中的图像 1,3 LG Muziq LX570 Front Case Replacement: 步骤 2 中的图像 2,3 LG Muziq LX570 Front Case Replacement: 步骤 2 中的图像 3,3
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Front Case Replacement: 步骤 3 中的图像 1,3 LG Muziq LX570 Front Case Replacement: 步骤 3 中的图像 2,3 LG Muziq LX570 Front Case Replacement: 步骤 3 中的图像 3,3
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
结论
Raymond Ching
于01/19/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G29
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 571
