跳转到主内容
LG Muziq LX570 Display Panel Replacement
你所需要的
  1. LG Muziq LX570 Display Panel Replacement, Front Case: 步骤 1 中的图像 1,2 LG Muziq LX570 Display Panel Replacement, Front Case: 步骤 1 中的图像 2,2
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Display Panel Replacement: 步骤 2 中的图像 1,3 LG Muziq LX570 Display Panel Replacement: 步骤 2 中的图像 2,3 LG Muziq LX570 Display Panel Replacement: 步骤 2 中的图像 3,3
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Display Panel Replacement: 步骤 3 中的图像 1,3 LG Muziq LX570 Display Panel Replacement: 步骤 3 中的图像 2,3 LG Muziq LX570 Display Panel Replacement: 步骤 3 中的图像 3,3
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
  4. LG Muziq LX570 Display Panel Replacement, Display Panel: 步骤 4 中的图像 1,3 LG Muziq LX570 Display Panel Replacement, Display Panel: 步骤 4 中的图像 2,3 LG Muziq LX570 Display Panel Replacement, Display Panel: 步骤 4 中的图像 3,3
    • Use the spudger to unclip the two upper wiring connections.
  5. LG Muziq LX570 Display Panel Replacement: 步骤 5 中的图像 1,2 LG Muziq LX570 Display Panel Replacement: 步骤 5 中的图像 2,2
    • Caution: The side buttons are attached to the ribbon around the display screen. Do not separate the side buttons from the ribbon when removing.
    • Gently lift the side buttons from the phone casing.
  6. LG Muziq LX570 Display Panel Replacement: 步骤 6 中的图像 1,3 LG Muziq LX570 Display Panel Replacement: 步骤 6 中的图像 2,3 LG Muziq LX570 Display Panel Replacement: 步骤 6 中的图像 3,3
    • Caution: The wiring on the ribbon connector is delicate. Do not excessively pull on the wires.
    • Use the spudger to remove the three components connected to the ribbon.
  7. LG Muziq LX570 Display Panel Replacement: 步骤 7 中的图像 1,3 LG Muziq LX570 Display Panel Replacement: 步骤 7 中的图像 2,3 LG Muziq LX570 Display Panel Replacement: 步骤 7 中的图像 3,3
    • Caution: The ribbon contains important wiring and is glued to the phone. Be careful when removing the ribbon.
    • Use the spudger to gently remove the ribbon from the phone.
  8. LG Muziq LX570 Display Panel Replacement: 步骤 8 中的图像 1,3 LG Muziq LX570 Display Panel Replacement: 步骤 8 中的图像 2,3 LG Muziq LX570 Display Panel Replacement: 步骤 8 中的图像 3,3
    • Use the spudger to lift the upper tab in the top left corner of the display.
    • Continue lifting until the display panels lift out of their setting and can be removed.
结论
Braden Burk
于01/22/12注册
1 声望
创作了5篇指南
团队
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G29
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,033
