跳转到主内容
LG Motion 4G MS770 Motherboard Replacement
你所需要的
  1. LG Motion 4G MS770 Motherboard Replacement, Remove the phone's back cover.: 步骤 1 中的图像 1,1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Motherboard Replacement, Remove the battery.: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Motherboard Replacement, Remove screws.: 步骤 3 中的图像 1,1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Motherboard Replacement: 步骤 4 中的图像 1,2 LG Motion 4G MS770 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Motherboard Replacement: 步骤 5 中的图像 1,2 LG Motion 4G MS770 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Motherboard Replacement, Speaker: 步骤 6 中的图像 1,2 LG Motion 4G MS770 Motherboard Replacement, Speaker: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  7. LG Motion 4G MS770 Motherboard Replacement, Rear Facing Camera: 步骤 7 中的图像 1,1
    • Pry slightly underneath the tab attached to the camera until it pops off.
  8. LG Motion 4G MS770 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use tweezers to remove the camera, you will need to use some force as it is glued on.
  9. LG Motion 4G MS770 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Pry off the circled tabs using a plastic opening tool to release the motherboard.
  10. LG Motion 4G MS770 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Lift the motherboard off of the phone. It should come right out.
结论
7等其他人完成本指南。
Zarna Patel
于10/08/14注册
320 声望
创作了2篇指南
团队
USF Tampa, Team 14-1, Leahy Fall 2014 USF Tampa, Team 14-1, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 1,299
