跳转到主内容
LG Leon LTE Motherboard Replacement
你所需要的
  1. LG Leon LTE Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 LG Leon LTE Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Turn the phone over so the back is facing upward.
  2. LG Leon LTE Motherboard Replacement: 步骤 2 中的图像 1,3 LG Leon LTE Motherboard Replacement: 步骤 2 中的图像 2,3 LG Leon LTE Motherboard Replacement: 步骤 2 中的图像 3,3
    • Insert your opening tool in the incision at the bottom center of the phone.
    • Push upward with the opening tool to pry the back of the phone open.
    • Remove the back completely and set aside.
  3. LG Leon LTE Motherboard Replacement: 步骤 3 中的图像 1,3 LG Leon LTE Motherboard Replacement: 步骤 3 中的图像 2,3 LG Leon LTE Motherboard Replacement: 步骤 3 中的图像 3,3
    • Using the Phillips #0 screwdriver, unscrew the 8 screws that secure the back frame to the body of the phone.
    • Remember to put the screws in a safe place so you don't lose them.
    • Once all screws are removed, use the opening tool to pry the back frame of the phone free.
  4. LG Leon LTE Motherboard Replacement: 步骤 4 中的图像 1,2 LG Leon LTE Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using the opening tool, gently pry the phone's earpiece off. Set aside.
    • Separate the old motherboard from the phone fixture by pulling it apart.
    • Gently press the replacement motherboard into the phone fixture.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 22
总计 732
