跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will teach you how to remove the battery from the LG LX160
  1. Place the phone on a flat surface with the back facing upward.
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  3. Once the panel is removed, you will see the battery.  Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  4. Remove the battery completely from the phone and place the battery off to the side.
    • Remove the battery completely from the phone and place the battery off to the side.
结论
David Baruela
于2010年01月14日注册
1 信誉积分
撰写一个指南
团队
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G2
5 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,139
