跳转到主内容
加入维修社区 - 创建账户
LG LX160 Back Casing Replacement
你所需要的
  1. LG LX160 Back Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Back Casing Replacement: 步骤 2 中的图像 1,1
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Back Casing Replacement: 步骤 3 中的图像 1,1
    • Remove the battery completely from the phone and place the battery off to the side.
  4. LG LX160 Back Casing Replacement, Back Casing: 步骤 4 中的图像 1,1
    • Now that the battery has been completely removed, hold the phone upright.
    • Pull off all rubber tabs covering the headphone jack and the power input port. Do this before continuing the next steps.
  5. LG LX160 Back Casing Replacement: 步骤 5 中的图像 1,1
    • Flip the phone with the backside facing up.
    • Using the Phillips #00 Screwdriver, unscrew the 6 screws that hold the back casing together.
  6. LG LX160 Back Casing Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Located at the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Pull up gently on the orange wire until it comes loose. Do not be concerned with gentleness, it may require some force.
结论
团队
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010 的会员
CPSU-FORTE-W10S11G2
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 73
总计 2,239
