简介
Use this guide to replace your Volume Toggle Button.
你所需要的
First locate the button and the bottom of the cover where the arrow is. Press down on the button.
While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
The battery will be visible after removing the back cover.
Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
To remove the volume toggle button, use the spudger to push the original button out of its socket.
After loosening the volume toggle button from its socket, finish pulling it out with your fingers.
2等其他人完成本指南。
