简介
Use this guide to remove the speakers from the device.
配件
无需配件。
  1. Use the spudger to pry out the indicated rubber squares. Use the #0 Phillips screwdriver to take out the revealed screws. Use the #0 Phillips screwdriver to take out the revealed screws.
    • Use the spudger to pry out the indicated rubber squares.
    • Use the #0 Phillips screwdriver to take out the revealed screws.
  2. Carefully lodge the spudger between the face plate and the hinge mechanism. Gently pry the face plate until it releases from place holders. Gently pry the face plate until it releases from place holders.
    • Carefully lodge the spudger between the face plate and the hinge mechanism.
    • Gently pry the face plate until it releases from place holders.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Using a spudger, detach the speakers from their place holders. Using a spudger, detach the speakers from their place holders.
    • Using a spudger, detach the speakers from their place holders.
  5. Using the spudger, pry between the speaker circuit board and base to detach with ease.
    • Using the spudger, pry between the speaker circuit board and base to detach with ease.
结论
2等其他人完成本指南。
Harry Black
于2010年04月20日注册
56 信誉积分
撰写一个指南
团队
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G44
4 名成员
创作了18篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,434
