跳转到主内容
LG LX150 Screen Replacement
你所需要的
  1. LG LX150 Screen Replacement, Front Cover: 步骤 1 中的图像 1,3 LG LX150 Screen Replacement, Front Cover: 步骤 1 中的图像 2,3 LG LX150 Screen Replacement, Front Cover: 步骤 1 中的图像 3,3
    • Use the spudger to pry out the indicated rubber squares.
    • Use the #0 Phillips screwdriver to take out the revealed screws.
  2. LG LX150 Screen Replacement: 步骤 2 中的图像 1,3 LG LX150 Screen Replacement: 步骤 2 中的图像 2,3 LG LX150 Screen Replacement: 步骤 2 中的图像 3,3
    • Carefully lodge the spudger between the face plate and the hinge mechanism.
    • Gently pry the face plate until it releases from place holders.
  3. LG LX150 Screen Replacement, Screen: 步骤 3 中的图像 1,2 LG LX150 Screen Replacement, Screen: 步骤 3 中的图像 2,2
    • Apply even amounts of force upon removing screen, otherwise cracking may occur.
    • Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
    • Carefully use both thumbs and apply pressure to the back of the screen to pop out.
结论
另外一个人完成了本指南。
Tye Barba
于04/15/10注册
88 声望
创作了2篇指南
团队
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G44
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,355
