跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This will show you how to remove the motherboard on your LG LX150
配件
没有特定配件。
  1. First locate the button and the bottom of the cover where the arrow is. Press down on the button. While pushing down on the button, slide the cover up towards the hinge until the cover comes off. The battery will be visible after removing the back cover.
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. Simultaneously push the battery forward and pull up from the bottom. Simultaneously push the battery forward and pull up from the bottom.
    • Simultaneously push the battery forward and pull up from the bottom.
  3. Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
  4. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  5. Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver. Insert the flat end of the spudger in-between the black and  blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners. Insert the flat end of the spudger in-between the black and  blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
    • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
    • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
  6. Remove the internal back cover after loosening all the corners. The second picture below is what you will see after removing the internal back cover.
    • Remove the internal back cover after loosening all the corners.
    • The second picture below is what you will see after removing the internal back cover.
  7. Lift the motherboard from the bottom to loosen it.
    • Lift the motherboard from the bottom to loosen it.
  8. Remove the pin socket that connects the screen to the motherboard by pulling up away from the motherboard.
    • Remove the pin socket that connects the screen to the motherboard by pulling up away from the motherboard.
  9. Remove the motherboard. The keypad will now be visible, as shown in the second picture.
    • Remove the motherboard.
    • The keypad will now be visible, as shown in the second picture.
结论
另外一个人完成了本指南。
Daniel Simpson
于2010年04月18日注册
60 信誉积分
创作了2篇指南
团队
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G44
4 名成员
创作了18篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 7
总计 1,380
