跳转到主内容
LG LX150 Keypad Replacement
你所需要的
  1. LG LX150 Keypad Replacement, Back Cover: 步骤 1 中的图像 1,3 LG LX150 Keypad Replacement, Back Cover: 步骤 1 中的图像 2,3 LG LX150 Keypad Replacement, Back Cover: 步骤 1 中的图像 3,3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Keypad Replacement, Battery: 步骤 2 中的图像 1,2 LG LX150 Keypad Replacement, Battery: 步骤 2 中的图像 2,2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Keypad Replacement: 步骤 3 中的图像 1,1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
  4. LG LX150 Keypad Replacement, Internal Back Cover: 步骤 4 中的图像 1,3 LG LX150 Keypad Replacement, Internal Back Cover: 步骤 4 中的图像 2,3 LG LX150 Keypad Replacement, Internal Back Cover: 步骤 4 中的图像 3,3
    • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
    • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
  5. LG LX150 Keypad Replacement: 步骤 5 中的图像 1,2 LG LX150 Keypad Replacement: 步骤 5 中的图像 2,2
    • Remove the internal back cover after loosening all the corners.
    • The second picture below is what you will see after removing the internal back cover.
  6. LG LX150 Keypad Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Lift the motherboard from the bottom to loosen it.
  7. LG LX150 Keypad Replacement: 步骤 7 中的图像 1,1
    • Remove the pin socket that connects the screen to the motherboard by pulling up away from the motherboard.
  8. LG LX150 Keypad Replacement: 步骤 8 中的图像 1,2 LG LX150 Keypad Replacement: 步骤 8 中的图像 2,2
    • Remove the motherboard.
    • The keypad will now be visible, as shown in the second picture.
  9. LG LX150 Keypad Replacement, Keypad: 步骤 9 中的图像 1,1
    • To remove the key pad, simply pull it off from the LG LX150 frame.
  10. LG LX150 Keypad Replacement: 步骤 10 中的图像 1,1
    • When the key pad is removed, the frame will be all that is left.
    • If you wish to replace the key pad, place the new keypad on to the frame and reassemble the phone to resume use.
结论
另外一个人完成了本指南。
Andrea
于04/19/10注册
110 声望
创作了4篇指南
团队
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 的会员
CPSU-GARNER-S10S10G44
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 910
