当前版本的文档还未经巡查,您可以查看最新的已查核版本。
First locate the button and the bottom of the cover where the arrow is. Press down on the button.
While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
The battery will be visible after removing the back cover.
Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
