跳转到主内容
LG L1200 Logic Board Replacement
你所需要的
  1. LG L1200 Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  2. LG L1200 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  3. LG L1200 Logic Board Replacement: 步骤 3 中的图像 1,1
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  4. LG L1200 Logic Board Replacement: 步骤 4 中的图像 1,1
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  5. LG L1200 Logic Board Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to disconnect antenna wire.
  6. LG L1200 Logic Board Replacement: 步骤 6 中的图像 1,1
    • Use the IPod opening tool to pop out the logic board.
  7. LG L1200 Logic Board Replacement: 步骤 7 中的图像 1,1
    • Use the IPod opening tool to disconnect the main ribbon.
  8. LG L1200 Logic Board Replacement: 步骤 8 中的图像 1,1
    • Once the ribbon is detached, remove the logic board and replace if necessary.
结论
Joshua Herrmann
于04/16/10注册
8 声望
创作了8篇指南
团队
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G14
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,210
