跳转到主内容
LG L1200 Internal Speaker Replacement
你所需要的
  1. LG L1200 Internal Speaker Replacement, Inner LCD Screen: 步骤 1 中的图像 1,1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Internal Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Internal Speaker Replacement: 步骤 3 中的图像 1,1
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Internal Speaker Replacement: 步骤 4 中的图像 1,3 LG L1200 Internal Speaker Replacement: 步骤 4 中的图像 2,3 LG L1200 Internal Speaker Replacement: 步骤 4 中的图像 3,3
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Internal Speaker Replacement: 步骤 5 中的图像 1,2 LG L1200 Internal Speaker Replacement: 步骤 5 中的图像 2,2
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Internal Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Internal Speaker Replacement: 步骤 7 中的图像 1,3 LG L1200 Internal Speaker Replacement: 步骤 7 中的图像 2,3 LG L1200 Internal Speaker Replacement: 步骤 7 中的图像 3,3
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Internal Speaker Replacement: 步骤 8 中的图像 1,3 LG L1200 Internal Speaker Replacement: 步骤 8 中的图像 2,3 LG L1200 Internal Speaker Replacement: 步骤 8 中的图像 3,3
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Internal Speaker Replacement: 步骤 9 中的图像 1,2 LG L1200 Internal Speaker Replacement: 步骤 9 中的图像 2,2
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Internal Speaker Replacement: 步骤 10 中的图像 1,2 LG L1200 Internal Speaker Replacement: 步骤 10 中的图像 2,2
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 Internal Speaker Replacement, Internal Speaker: 步骤 11 中的图像 1,1
    • Desolder the wires connecting the speaker.
    • Solder on wires from new speaker.
结论
Joshua Herrmann
于04/16/10注册
8 声望
创作了8篇指南
团队
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G14
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 11
总计 1,425
