跳转到主内容
LG KP100 Motherboard Replacement
你所需要的
  1. LG KP100 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG KP100 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin by taking the back battery cover off.
    • Put your index finger on the white notch and apply pressure.
    • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. LG KP100 Motherboard Replacement: 步骤 2 中的图像 1,2 LG KP100 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the battery.
    • Put your index finger in the notch above the battery near the top of the casing.
    • While applying pressure against the battery, lift up and take out the battery.
  3. LG KP100 Motherboard Replacement, SIM Card: 步骤 3 中的图像 1,3 LG KP100 Motherboard Replacement, SIM Card: 步骤 3 中的图像 2,3 LG KP100 Motherboard Replacement, SIM Card: 步骤 3 中的图像 3,3
    • Remove the SIM card from its housing.
    • Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device.
    • After it is out of the metal housing, it is free to be removed.
  4. LG KP100 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the four screws along the edge of the phone body, as shown in the picture to the left.
  5. LG KP100 Motherboard Replacement: 步骤 5 中的图像 1,2 LG KP100 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, pry open the body of the phone, starting at the bottom of the phone (this tends to be the easiest place to start).
    • Double check to make sure the SIM card is removed from its housing. You will not be able to pry open the body of the phone if the SIM card remains in its housing.
    • Continue by sliding the opening tool around the perimeter of the phone. You should hear multiple clicking sounds as you complete this, indicating the clips are becoming unlatched.
    • This may take a few tries to get correct. Don't give up if it doesn't work the very first time.
  6. LG KP100 Motherboard Replacement: 步骤 6 中的图像 1,3 LG KP100 Motherboard Replacement: 步骤 6 中的图像 2,3 LG KP100 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Put the red casing aside and remove the motherboard from the front casing of the phone by carefully dislodging it from its two clips near the top of the phone.
结论
Preston Brown
于04/12/12注册
28 声望
创作了5篇指南
团队
Cal Poly, Team 6-20, Amido Spring 2012 Cal Poly, Team 6-20, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G20
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,133
