跳转到主内容
LG K7 Volume & On/Off Buttons Replacement
你所需要的
  1. LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: 步骤 1 中的图像 1,2 LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: 步骤 1 中的图像 2,2
    • Remove the back cover using a plastic opening tool.
    • Remove the battery using a plastic opening tool.
  2. LG K7 Volume & On/Off Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Volume & On/Off Buttons Replacement: 步骤 3 中的图像 1,1
    • Pry off the silver button housing using the plastic opening tool.
  4. LG K7 Volume & On/Off Buttons Replacement: 步骤 4 中的图像 1,1
    • Separate the screen from the rest of the phone using the plastic opening tool.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Volume & On/Off Buttons Replacement: 步骤 5 中的图像 1,3 LG K7 Volume & On/Off Buttons Replacement: 步骤 5 中的图像 2,3 LG K7 Volume & On/Off Buttons Replacement: 步骤 5 中的图像 3,3
    • Peel off the orange cable using a plastic opening tool.
  6. LG K7 Volume & On/Off Buttons Replacement: 步骤 6 中的图像 1,1
    • Remove the volume/power button cable from the rest of the phone using the plastic opening tool to break the adhesive.
结论
另外一个人完成了本指南。
Jack Lepkowski
于11/07/19注册
136 声望
撰写一个指南
团队
IUPUI, Team S3-G2, Harley Fall 2019 IUPUI, Team S3-G2, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S3G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 505
