跳转到主内容
LG K7 T-Mobile Motherboard Replacement
你所需要的
  1. LG K7 T-Mobile Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG K7 T-Mobile Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Motherboard Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the battery.
  4. LG K7 T-Mobile Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 LG K7 T-Mobile Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Motherboard Replacement: 步骤 5 中的图像 1,3 LG K7 T-Mobile Motherboard Replacement: 步骤 5 中的图像 2,3 LG K7 T-Mobile Motherboard Replacement: 步骤 5 中的图像 3,3
    • Turn the phone over so the screen is facing up.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Motherboard Replacement: 步骤 6 中的图像 1,3 LG K7 T-Mobile Motherboard Replacement: 步骤 6 中的图像 2,3 LG K7 T-Mobile Motherboard Replacement: 步骤 6 中的图像 3,3
    • Locate the lock that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
  7. LG K7 T-Mobile Motherboard Replacement: 步骤 7 中的图像 1,2 LG K7 T-Mobile Motherboard Replacement: 步骤 7 中的图像 2,2
    • Locate the headphone jack towards the bottom right of the phone.
    • Place a plastic removal tool underneath the head phone jack.
    • Lift the plastic removal tool upward to remove the earphone jack from the phone case.
  8. LG K7 T-Mobile Motherboard Replacement: 步骤 8 中的图像 1,2 LG K7 T-Mobile Motherboard Replacement: 步骤 8 中的图像 2,2
    • Locate the ribbon for the front facing camera.
    • Carefully remove the front facing camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the front camera ribbon you just released pull upwards and the camera should release from the case.
    • Remove the band that connects the screen display to the motherboard.
  9. LG K7 T-Mobile Motherboard Replacement: 步骤 9 中的图像 1,2 LG K7 T-Mobile Motherboard Replacement: 步骤 9 中的图像 2,2
    • Locate the ribbon cable that connects the screen to the motherboard.
    • Carefully remove the screen's ribbon cable from the motherboard using the plastic removal tool by lifting the ribbon cable upwards.
  10. LG K7 T-Mobile Motherboard Replacement: 步骤 10 中的图像 1,3 LG K7 T-Mobile Motherboard Replacement: 步骤 10 中的图像 2,3 LG K7 T-Mobile Motherboard Replacement: 步骤 10 中的图像 3,3
    • Wedge a plastic opening tool between the motherboard and the phones casing.
    • While using one finger to hold down a portion of the phone pull upwards with the plastic opening tool to loosen the motherboard from the phone casing.
    • Once there is some space between the board and the phone case, using your hands carefully lift the motherboard from the phone casing.
结论
7等其他人完成本指南。
Brandon Jones
于09/28/17注册
233 声望
撰写一个指南
团队
USF Tampa, Team S2-G5, Nance Fall 2017 USF Tampa, Team S2-G5, Nance Fall 2017 的会员
USFT-NANCE-F17S2G5
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 2,197
