跳转到主内容
加入维修社区 - 创建账户
LG K7 Screen Replacement
你所需要的
  1. LG K7 Screen Replacement, Screen: 步骤 1 中的图像 1,3 LG K7 Screen Replacement, Screen: 步骤 1 中的图像 2,3 LG K7 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Place phone face-down and use your nail to pry the back off the back.
  2. LG K7 Screen Replacement: 步骤 2 中的图像 1,2 LG K7 Screen Replacement: 步骤 2 中的图像 2,2
    • Use a plastic spudger or your nail to lift the battery out of the device and put it aside.
    • The battery should come out with little effort. If it does not, do not force it.
  3. LG K7 Screen Replacement: 步骤 3 中的图像 1,3 LG K7 Screen Replacement: 步骤 3 中的图像 2,3 LG K7 Screen Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the single 3.5mm screw holding the power button and volume rocker in place and lift it out and put it to the side.
  4. LG K7 Screen Replacement: 步骤 4 中的图像 1,3 LG K7 Screen Replacement: 步骤 4 中的图像 2,3 LG K7 Screen Replacement: 步骤 4 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the three 3.5mm screws in the bottom portion of the phone and put them to the side.
    • Use a spudger to pry the plastic bit off. Be warned, it will pop out and might fling itself when you attempt to pry it out.
  5. LG K7 Screen Replacement: 步骤 5 中的图像 1,3 LG K7 Screen Replacement: 步骤 5 中的图像 2,3 LG K7 Screen Replacement: 步骤 5 中的图像 3,3
    • Warning, it will snap out and might fling itself when you attempt to pry it out.
  6. LG K7 Screen Replacement: 步骤 6 中的图像 1,3 LG K7 Screen Replacement: 步骤 6 中的图像 2,3 LG K7 Screen Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the five 3.5mm screws holding the housing into the device.
    • Use a spudger to pop it out of the back of the device exposing the motherboard.
  7. LG K7 Screen Replacement: 步骤 7 中的图像 1,3 LG K7 Screen Replacement: 步骤 7 中的图像 2,3 LG K7 Screen Replacement: 步骤 7 中的图像 3,3
    • Use a plastic spudger to lift the motherboard out of the casing.
    • You must use a plastic tool for this step or you may risk damaging the motherboard.
  8. LG K7 Screen Replacement: 步骤 8 中的图像 1,3 LG K7 Screen Replacement: 步骤 8 中的图像 2,3 LG K7 Screen Replacement: 步骤 8 中的图像 3,3
    • Turn the device over and locate the connector between the digitizer and the motherboard.
    • Use a plastic spudger to disconnect the connector.
  9. LG K7 Screen Replacement: 步骤 9 中的图像 1,1
    • Turn the screen housing over and use a hair dryer to heat the screen.
    • This melts the adhesive between the screen and the housing, allowing you to separate the two.
    • Be sure to evenly heat the screen and take care not to burn yourself.
  10. LG K7 Screen Replacement: 步骤 10 中的图像 1,1
    • Once the screen is heated, use a plastic spudger to attempt to peel the glass away from the housing.
    • This will take some time, so take care not to break the glass.
    • Once the spudger is under the glass, drag it around the edge and separate the glass and the housing.
  11. LG K7 Screen Replacement: 步骤 11 中的图像 1,2 LG K7 Screen Replacement: 步骤 11 中的图像 2,2
    • You have now successfully removed the screen and digitizer from the housing.
结论
8等其他人完成本指南。
团队
IUPUI, Team S3-G4, Harley Fall 2018 IUPUI, Team S3-G4, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S3G4
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 1,927
