跳转到主内容
LG K7 Rear Facing Camera Replacement
你所需要的
  1. LG K7 Rear Facing Camera Replacement, Battery: 步骤 1 中的图像 1,2 LG K7 Rear Facing Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Rear Facing Camera Replacement: 步骤 2 中的图像 1,2 LG K7 Rear Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 3 中的图像 1,3 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 3 中的图像 2,3 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 3 中的图像 3,3
    • Remove the 9 frame screws with a JIS #00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 LG K7 Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to separate the screen from the outer frame.
    • Do not to bend the outer frame or the screen to when separating them. This can severely damage the phone.
  5. LG K7 Rear Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Insert the edge of a plastic opening tool underneath the camera connector that is attached to the camera by a flat, thin, and flexible sheet.
    • Slowly lever the connector free by pressing down on the opening tool's handle. The connector should be fairly solid and pop out by levering just one edge.
    • Be careful not to break or bend the connector or any part of the device you may be levering against.
结论
另外一个人完成了本指南。
James Ngo
于01/19/18注册
461 声望
创作了4篇指南
团队
Cal Poly, Team S21-G5, Banghart Winter 2018 Cal Poly, Team S21-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S21G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 399
