跳转到主内容
LG K7 Motherboard Replacement
你所需要的
  1. LG K7 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 LG K7 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 LG K7 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Place phone face-down and use your nail to pry the back off the back.
  2. LG K7 Motherboard Replacement: 步骤 2 中的图像 1,2 LG K7 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a plastic spudger or your nail to lift the battery out of the device and put it to the side.
    • The battery should lift out with little effort. If it does not, do not force it.
  3. LG K7 Motherboard Replacement: 步骤 3 中的图像 1,3 LG K7 Motherboard Replacement: 步骤 3 中的图像 2,3 LG K7 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the single 3.5 mm screw holding the power button and volume rocker in place and lift it out and put it to the side.
  4. LG K7 Motherboard Replacement: 步骤 4 中的图像 1,3 LG K7 Motherboard Replacement: 步骤 4 中的图像 2,3 LG K7 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the three 3.5mm screws in the bottom portion of the phone and put them to the side.
  5. LG K7 Motherboard Replacement: 步骤 5 中的图像 1,3 LG K7 Motherboard Replacement: 步骤 5 中的图像 2,3 LG K7 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to pry the plastic bit off. Be warned, it will snap out and might fling itself when you attempt prying it out.
  6. LG K7 Motherboard Replacement: 步骤 6 中的图像 1,3 LG K7 Motherboard Replacement: 步骤 6 中的图像 2,3 LG K7 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #0 screwdriver to unscrew the five 3.5 mm screws holding the housing into the device and use a spudger to pop it out of the back of the device exposing the motherboard.
  7. LG K7 Motherboard Replacement: 步骤 7 中的图像 1,3 LG K7 Motherboard Replacement: 步骤 7 中的图像 2,3 LG K7 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Use a plastic spudger to lift the motherboard out of the casing.
    • You must use a plastic tool for this step or you may risk shorting the logic board.
  8. LG K7 Motherboard Replacement: 步骤 8 中的图像 1,3 LG K7 Motherboard Replacement: 步骤 8 中的图像 2,3 LG K7 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Turn the device over and locate the connector between the digitizer and the motherboard.
    • Use a plastic spudger to disconnect the connector.
  9. LG K7 Motherboard Replacement: 步骤 9 中的图像 1,2 LG K7 Motherboard Replacement: 步骤 9 中的图像 2,2
    • You have now successfully removed the motherboard from your LG K7.
结论
另外一个人完成了本指南。
团队
IUPUI, Team S3-G4, Harley Fall 2018 IUPUI, Team S3-G4, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S3G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 800
