跳转到主内容
LG K30 Battery Replacement
你所需要的
  1. LG K30 Battery Replacement, Battery: 步骤 1 中的图像 1,2 LG K30 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Battery Replacement: 步骤 3 中的图像 1,1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Battery Replacement: 步骤 5 中的图像 1,2 LG K30 Battery Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
结论
11等其他人完成本指南。
一条评论
There's no description of removing the display or supporting it. Why is an LG K30 screen with frame required?
P Schmied - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 45
总计 12,914
