跳转到主内容
LG K20 PLUS Midframe Replacement
你所需要的
  1. LG K20 PLUS Midframe Replacement, Remove the back cover and battery: 步骤 1 中的图像 1,2 LG K20 PLUS Midframe Replacement, Remove the back cover and battery: 步骤 1 中的图像 2,2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Midframe Replacement, Midframe: 步骤 2 中的图像 1,1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Midframe Replacement: 步骤 3 中的图像 1,2 LG K20 PLUS Midframe Replacement: 步骤 3 中的图像 2,2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
结论
Patrick
于05/14/14注册
6,586 声望
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 73
