跳转到主内容
LG Intuition Camera Replacement
你所需要的
  1. LG Intuition Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device so the two bottom screws are shown.
  2. LG Intuition Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
  3. LG Intuition Camera Replacement: 步骤 3 中的图像 1,1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
  4. LG Intuition Camera Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
  5. LG Intuition Camera Replacement: 步骤 5 中的图像 1,1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
  6. LG Intuition Camera Replacement: 步骤 6 中的图像 1,2 LG Intuition Camera Replacement: 步骤 6 中的图像 2,2
    • Gently raise the battery from its compartment.
  7. LG Intuition Camera Replacement, Plastic Motherboard Shield: 步骤 7 中的图像 1,1
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
  8. LG Intuition Camera Replacement: 步骤 8 中的图像 1,1
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
  9. LG Intuition Camera Replacement, Camera: 步骤 9 中的图像 1,1
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
  10. LG Intuition Camera Replacement: 步骤 10 中的图像 1,1
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
结论
Thomas Morrissey
于10/25/18注册
616 声望
创作了6篇指南
团队
UMass Dartmouth, Team S3-G4, Peak Fall 2018 UMass Dartmouth, Team S3-G4, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G4
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 188
