跳转到主内容
LG Incite Back Panel Replacement
你所需要的
  1. LG Incite Back Panel Replacement, Battery: 步骤 1 中的图像 1,1
    • Hold the phone camera-side up and locate the rear cover.
  2. LG Incite Back Panel Replacement: 步骤 2 中的图像 1,1
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
  3. LG Incite Back Panel Replacement: 步骤 3 中的图像 1,1
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
  4. LG Incite Back Panel Replacement, Back Panel: 步骤 4 中的图像 1,1
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
  5. LG Incite Back Panel Replacement: 步骤 5 中的图像 1,1
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
  6. LG Incite Back Panel Replacement: 步骤 6 中的图像 1,1
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
结论
Kimberly Kha
于04/16/13注册
163 声望
创作了5篇指南
团队
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013 的会员
CPSU-MANESS-S13S2G18
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 20
总计 719
