跳转到主内容
加入维修社区 - 创建账户
LG Grace Prerequisite Dissasembly
你所需要的
  1. LG Grace Prerequisite Dissasembly, Phone Assembly: 步骤 1 中的图像 1,1
    • Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
  2. LG Grace Prerequisite Dissasembly: 步骤 2 中的图像 1,1
    • Pull the battery out of the back of the phone. A small indent is present to allow you to pry it out but you may also just flip the phone over and strike it gently against your palm.
  3. LG Grace Prerequisite Dissasembly: 步骤 3 中的图像 1,2 LG Grace Prerequisite Dissasembly: 步骤 3 中的图像 2,2
    • Unscrew all of the screws now visible on the back panel of the phone--11 in total. A #00 Phillips screwdriver works here.
    • The screws are M1.3 and 3 mm long.
  4. LG Grace Prerequisite Dissasembly: 步骤 4 中的图像 1,2 LG Grace Prerequisite Dissasembly: 步骤 4 中的图像 2,2
    • Insert the Jimmy into the small gap between the edge of the phone screen and body. Gently pry until it pops loose then remove jimmy and use your hands to slowly pry the body away from the screen
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 193
