简介
If your LG Grace smartphone, model # LGL59BL, is borked and you can't figure out why, it may be your motherboard. The motherboard is responsible for essentially everything the phone does. It is the neurons of your phone's brain, and this means that when it goes wrong, diagnosing it can be much less specific than in the case of a camera or speaker.
Consulting this guide will give you some guidance, but really this is a diagnosis by exclusion.
Please note that this guide requires the removal of the phone's battery, and while this is a trivial task with this particular model, if your battery is swollen and stuck then prying at it could potentially cause it to rupture and explode. Please power off your device and take it to a repair professional or someone else trained in safely disposing of the malfunctioning battery. As a general rule of thumb, always turn off any device you are working on.
All in all this is a relatively simple replacement and requires no special skills, so don't be intimidated. A replacement part may be a little expensive considering the price of a new phone with similar specs, but it's still understandable that you would want to replace your motherboard if your intent is keeping as much out of the land fill as possible.
你所需要的
Find the indentation along the edge of the phone's back and pry open with your nail. A pry tool may help if you have short nails but shouldn't be necessary.
Locate the pin connection for the camera, noted by red box in the guide photo.
Gently lift the camera up while pulling away from connection; it should detach with minimal effort.
Next we remove the front speaker from the motherboard, with the goal of removing all connections that hold the board in place.
The location of the speaker is highlighted in the guide photo.
Just like with the camera, gently pull the ribbon wire away from the connector and it should release easily.
