跳转到主内容
加入维修社区 - 创建账户
LG GW910 Keyboard Replacement
你所需要的
  1. LG GW910 Keyboard Replacement, Motherboard: 步骤 1 中的图像 1,2 LG GW910 Keyboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. LG GW910 Keyboard Replacement: 步骤 2 中的图像 1,2 LG GW910 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by lifting from the bottom.
  3. LG GW910 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove six 3mm PH000 screws.
  4. LG GW910 Keyboard Replacement: 步骤 4 中的图像 1,3 LG GW910 Keyboard Replacement: 步骤 4 中的图像 2,3 LG GW910 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. LG GW910 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. LG GW910 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. LG GW910 Keyboard Replacement: 步骤 7 中的图像 1,3 LG GW910 Keyboard Replacement: 步骤 7 中的图像 2,3 LG GW910 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
  8. LG GW910 Keyboard Replacement, Keyboard: 步骤 8 中的图像 1,1
    • Remove six 1mm PH00 screws.
  9. LG GW910 Keyboard Replacement: 步骤 9 中的图像 1,2 LG GW910 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Peel off the tape to expose the hidden screw.
    • Replacement tape might be needed.
  10. LG GW910 Keyboard Replacement: 步骤 10 中的图像 1,2 LG GW910 Keyboard Replacement: 步骤 10 中的图像 2,2
    • Pry off the board from the side using the metal spudger tool.
    • Disconnect the antenna.
  11. LG GW910 Keyboard Replacement: 步骤 11 中的图像 1,1
    • Remove the keyboard assembly from the main frame.
    • The keyboard cover is loose.
    • Make sure to pull the small keyboard battery out with the whole assembly
结论
另外一个人完成了本指南。
Jonas Ke
于11/06/18注册
492 声望
创作了3篇指南
团队
IUPUI, Team S1-G6, Hovde Fall 2018 IUPUI, Team S1-G6, Hovde Fall 2018 的会员
IUPUI-HOVDE-F18S1G6
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 230
