跳转到主内容
LG GS170 Battery Replacement
  1. LG GS170 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 LG GS170 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 LG GS170 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Turn off the the cell phone.
    • Locate the the arrow at the top of the back cover.
    • Slide the cover downward until the cover comes off.
  2. LG GS170 Battery Replacement, Battery: 步骤 2 中的图像 1,3 LG GS170 Battery Replacement, Battery: 步骤 2 中的图像 2,3 LG GS170 Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Completely remove the back cover, and the battery should be visible.
    • Locate the gap at the bottom right.
    • Use your thumb to pop out the battery.
  3. LG GS170 Battery Replacement: 步骤 3 中的图像 1,1
    • The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
    • Be careful of damaged battery. Inspect the battery for crack, rupture of the plastic, excessive leaking, or discoloration. Remove the battery carefully if it appears damaged.
结论
另外一个人完成了本指南。
Minna
于10/08/14注册
101 声望
撰写一个指南
团队
USF Tampa, Team 1-25, Donnelly Fall 2014 USF Tampa, Team 1-25, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G25
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 449
