跳转到主内容
LG G7 ThinQ Battery Replacement
你所需要的
  1. LG G7 ThinQ Battery Replacement, SIM Card: 步骤 1 中的图像 1,1
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
  2. LG G7 ThinQ Battery Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
  3. LG G7 ThinQ Battery Replacement, Speaker System: 步骤 3 中的图像 1,1
    • This device did not come with a midframe, but if yours does, follow the instructions in the teardown video to remove it.
    • Remove the screws along the perimeter and central area of the phone using a Phillips #000 screwdriver.
  4. LG G7 ThinQ Battery Replacement, Remove the speaker system: 步骤 4 中的图像 1,1
    • Use your fingers or tweezers to remove the speaker system.
  5. LG G7 ThinQ Battery Replacement, Remove the battery: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Use a nylon spudger to disconnect the two clips holding down the battery: one on the bottom and one on the top.
    • There is glue holding down the battery so be careful when removing it.
    • Pry the battery out of the phone with a nylon spudger.
    • Alternatively, slide a flat plastic card underneath the battery to separate it from the frame.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
结论
10等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 55
过去 30 天: 353
总计 12,770
